Need to get some inclusions/exclusions regarding the below need:
There is the single root folder = Pixiv.
1. include only the following subfolders (of the above root) and all files in those subfolders (w/o exception).
subfolder "###"
subfolder "zzzCategory"
subfolder "zzzTag"
subfolder "zMisc"
2. the following file types in root folder only:
*.bat
*.lnk
*.ps1
*.url
exclude all the following:
all other subfolders (of the above root) not already included/listed in 1. above
ALL files (w/o exception) in these subfolders.
From other posts, I understand this may require more than one line item.
Use a first left-right base location pair with a local Include Filter in which you replace the default * (=everything) by
\zzzCategory\
\zzzTag\
\zMisc\
(assuming all above subfolders are direct children of the left-right base directories)
2)
Use a second, identical left-right base location pair with
a local Include Filter in which you replace the default * by
*.bat
*.lnk
*.ps1
*.url
and a local Exclude Filter
Note that you define local (=left-right pair specific) Filter settings via the funnel icon mid between each left-right base folder pair.
\zzzCategory\
\zzzTag\
\zMisc\
2)
*.bat
*.lnk
*.ps1
*.url
Perfection! It worked (of course! Well played!)
I appreciate what you do ;)
