Mouse positioning
Patrice15220
Since the last version (14.7), the automatic placement of the mouse pointer on the default button no longer works despite correct configuration in Windows 11.
Is this intentional?
Thanks!
This is probably collateral damage of the following bug (which is fixed for the next release): viewtopic.php?t=12856
Patrice15220
Thank you for your reply. It works with beta version 14.8.
