I found the option to shutdown my PC on completion or on errors or success
JAK
but its rather buried, this option is important especially for unattended running, it should be more prominent, possibly in the options or main page.
it also should not need a command line to be typed, should be a simple drop down option for shutdown / sleep / hibernate, on various program outcomes.
love this program....
This wouldn't make since in the option or main page as not all sync configs should result in the same post-sync actions. Some prefilled options would be a nice quality of life update. It's not buried, users should be referring to documentation for features, or plain old tinkering around in menus ¯\_(ツ)_/¯
JAK
When I type the command line to shutdown on completion, it
automatically adds the same line to 'on error' and 'success' As you state
shouldn't these be allowed to have different actions _ Think a simple
drop down option for each action would be easier than typing in a command
line
The command you specify is, depending on which one you select, either run On Completion, or On Errors or On Success. You can not select more than one event.
JAK
So
Therefore, it should be easy to add a drop down menu to choose shutdiwn / hibernate / sleep for any event, simple really
> ... it should be easy to add a drop down menu ...
The source code is available.
If, as you wrote, it is easy, you can simply add it yourself ...
JAK
lol
