Is it possible to change the view, for example after a comparison, so that only the folders are displayed and not the folder and the files it contains?
For example, click on a specific folder icon to hide the items it contains. Clicking on the folder icon again will display the items it contains.
This can improve the overview when comparing many folders with many files in them.
Change view in order to improve the overview
Not exactly what you are asking for, but in the Overview window (bottom right in the FFS GUI), you can "browse" your left and right location(s). If you select a (sub)folder in the Overview window, the Compare results related to that folder are "highlighted" in the left and right Compare results window.
*Bottom-leftNot exactly what you are asking for, but in the Overview window (bottom right in the FFS GUI), you can "browse" your left and right location(s). If you select a (sub)folder in the Overview window, the Compare results related to that folder are "highlighted" in the left and right Compare results window. Plerry, 28 Jan 2026, 08:48
Thanks for the correction. Bottom-left it is.
Thank you, I understand. That was already clear to me.
