Change location where the ffs_gui files are stored
CWB
How do I change the location of the folder where the ffs_gui files are stored?
By using "Save", the (modified) current sync configuration is saved in its present location.
By using "Save as", you can save the sync configuration under any self selected name in any self selected location.
