Problems with single files
Mazz
I've (maybe) a problem: when I try to make a backup of a directory which contains subdirectories and files it happens as a result that I've, in backup destination, backup of Subdirectories but not single files... I didn't set any filter. Could you have any suggestion?
Thank you
Matteo
How have you determined this? Can you post a screenshot that shows your source with files and the corresponding directory on the backup that lacks those files?
