Hello
I would like to do the feature request to a pre-sync command, which would therefore be the counterpart of post-sync command.
This would be particularly useful in my user case because before each synchronization, I run a script that scans my various git repos and perform a compresion on them.
Thanks.
Else, I would like to take this opportunity to thank you for FreeFileSync, realy by far the best files synchronize sofware. Graphical, advanced but still intuitive, and with a comprehensive and quite editable config file, yeah, really perfet for me.
Feature Request: Pre-Sync Command
You can run FFS via CLI. Just have your script run the FFS sync after it completes
