Excluding files in subfolders
ukdave
I have a sync set of folders that runs for c:\Users\Dave\AppData => d:\backups.
I have a set of subfolders and files that i exclude, but i now want to try and exclude a specific set of files in a specific set of folders under a folder.
For example:
The sync above works great, but i want to exclude from this folder
c:\Users\Dave\AppData\Local\Microsoft\Onedrive\
all *.db files that are in different subfolders.
eg
\OneDrive\ListSync\*\settings\*.db
\Onedrive\settings\*\*.db
So i would like to exclude all *.db from all subfolders under \OneDrive\.
I have tried several combinations, but i can not find a way of making the wildcard match in all subfolders.
Am i missing something or do i just need to add in each subfolder that i want to exclude?
Cheers,
Dave
Gianni1962
For this sync-set folder pair:
to exclude from folder:
put this in the exclude section:
\Local\Microsoft\Onedrive\*.db
Note the relative path to the left/(right) folder pair.
Gianni1962
I have noticed that this way will be filtered out also this folder and its files despite they are not *.db:
c:\Users\Dave\AppData\Local\Microsoft\OneDrive\EBWebView\Default\EdgeCoupons\coupons_data.db
Appending a colon (:) to the filter expression, like stated in the manual, doesn't seem to work:
\Local\Microsoft\Onedrive\*.db:
Am I using the colon correctly?
A workaround is:
- add a folder pair with the same left and right folders
- move the Exclude filter from the Common settings to the Local settings of the first folder pair
- put this in the Include filter of the Local settings of the second folder pair
\Local\Microsoft\Onedrive\*.db\*
Or is there a better way?
Obviously coupons_data.db does match *.db, irrespective if coupons_data.db is a file or folder.
However, if coupons_data.db is a folder, it should not match *.db: (with its appended colon).
The usage of the colon seems correct. If that does not work, I don't know why not.
Fortunately, there are often more ways to skin a cat, and your workaround works as intended.
Gianni1962
Appending a colon in the Exclude filter, the folder is not excluded but the files in it are excluded, despite they are not *.db.
Appending a colon in the Exclude filter, the folder is not excluded but the files in it are excluded, despite they are not *.db. Gianni1962, 05 Feb 2026, 13:54
Hey you found a bug! Fixed: https://www.mediafire.com/file/de75p43ijhdash3/FreeFileSync_14.8_%255BBeta%255D_Windows_Setup%25283%2529.exe
Gianni1962
Thanks Zenju!
Now the colon works as expected!
