[Feature Request] Mirror files without rescanning the destination
ricoh83
Hello all,
I am looking for a feature in RealTime Sync where the program gives an option to disable scanning the destination folder altogether and syncing the changes almost immediately. That will really help in boosting up the realtime sync speed. Possible ?
Thank you :)
It can't know what to mirror without scanning
ricoh83
The program will scan the full destination for the very first time only or only if the user initiates a manual scan. After that, the program will track only changes to the source the rule being that there should be no changes be made to the destination by the user in this scenario.
