Build issue on linux
daviank
Dear Zenju,
Build is failing on linux because it expects file zen/warn_static.h which doesn't exist anymore. (14.7 & 14.8)
g++ -std=c++23 -pipe -DWXINTL_NO_GETTEXT_MACRO -I../.. -I../../zenXml -include "zen/i18n.h" -include "zen/warn_static.h" -Wall -Wfatal-errors -Wmissing-include-dirs -Wswitch-enum -Wcast-align -Wnon-virtual-dtor -Wno-unused-function -Wshadow -Wno-maybe-uninitialized -DNDEBUG `wx-config --version=3.2 --cxxflags --debug=no` -pthread `pkgconf --cflags openssl` `pkgconf --cflags libcurl` `pkgconf --cflags libidn2` `pkgconf --cflags libssh2` `pkgconf --cflags gtk+-3.0` -isystem/usr/include/gtk-3.0 `pkgconf --cflags libselinux` -DHAVE_SELINUX `pkgconf --cflags zlib` -c ffs_paths.cpp -o /tmp/FreeFileSync_Make/ffs/src/ffs_paths.cpp.o
<command-line>: fatal error: zen/warn_static.h: No such file or directory
Could you please fix this in your sources?
Thanks.
Thanks, fixed!
daviank
Thank you!
tee
You need to bump the version number with every new release however minor, otherwise this causes problems for package maintainers downstream.
