automatic backup of external hard drive
I,ve just downloaded and started using Freefilesync for the first. How do I set it up to automatically backup once I connect the external hard drive rather than having it set up on daily backup through windows task scheduler. I,m running XP at present
It seems you could create an AutoRun item on your external drive,
that is triggered upon insertion/connection of that external drive.
Obviously, AutoRun needs to be enabled in your XP (which it is by default).
Your AutoRun.inf file could then refer to a FFS batch file you created.
As drive letters may vary, you might use FFS's method of referring to
the drive's name (see the FFS help).
Oh nice, I did not know about this feature, that can be found in the help under "Variable drive letters". Well, I do not use storage via USB.
Reminds me on the resolution of environment vars in the backup target and versioning folders, when you hover over them, thats a very handy idea, too.
If you are not talking about a hot-swappable hard drive, it seems you refer to a drive,
possibly a network drive, that might or might not be available during startup.
In that case, a batch-file in the Startup menu might do the trick.
This batch-file would then need to check if the external HD is available, e.g.
by checking for the exitence of a predefined file on that drive, and if the drive
is available launches the FFS batch-file.
RealTimeSync ?
RealTimeSync
The primary purpose of RealTimeSync is to execute a command line ... when a directory becomes available (e. g. insert of a USB-stick).
RealTimeSync
