How to turn off the DOORBELL notification when finished
How do I eliminate the DOORBELL notification when a backup is completed? I don't need any audio notification and certainly not the sound of my doorbell being rung. Thanks.
In the FFS GUI, go to Tools/Options.
There you can delete the specification of the location of the sound wav-file (resulting in no sound when a sync finishes), or replace it by the location of another sound wav-file.
There you can delete the specification of the location of the sound wav-file (resulting in no sound when a sync finishes), or replace it by the location of another sound wav-file. Plerry, 02 Mar 2026, 09:40
Thanks Perry, I could not find this previously.In the FFS GUI, go to Tools/Options.
Dave
