EDIT SYNC TIMES?
David Abineri
I have set up a couple of sync tasks but now i need to edit the times at which they occur. How do I edit these times for specific tasks. Thanks
Assuming Windows, and that you use the Windows Task Manager to launch those sync tasks:
Open the Task Manager, select the sync task you want to change, and then edit the time or event that triggers the start of that sync.
