Automaticaly ignore file sync errors
nestrejg
Is there no option to ignore all file errors during sync? Because almost every time I leave FFS to backup my files overnight it has paused midways because there was an error syncing a file or some other minor issue. I can choose "Ignore all" and FFS continues. This is a bit frustrating. At least FFS should leave problematic files and errors to the very end of the sync, and not while it's still two hours left of the sync >:)
Checkmark "Ignore errors" when saving your *.ffs_batch sync configuration.
Hemps
One gripe I have with ignore errors - is it'll also ignore "The following folders are significantly different"
Nice safety feature in case source gets hammered by mass file deletion or ransomware.
