Random "ERROR_CANT_ACCESS_FILE [MoveFileEx]" during synchronization to local folder
andreino
Hi everyone,
I am experiencing an intermittent issue while syncing a network folder to a local folder.
Scenario:
Source: Network Share (UNC path/Mapped Drive)
Structure: The source files are located within subfolders that are Junction Points (not physical directories).
Destination: Local Drive
Permissions: Full read/write access on both ends. Manual file copying works perfectly without any errors, so NTFS permissions don't seem to be the culprit.
The Issue:
Step 1 (Compare): Works fine. It correctly identifies files to be deleted, updated, or copied.
Step 2 (Synchronize): This is where it fails randomly.
"Cannot rename [local_path\file_name.ffs_tmp] to [file_name.ext]. ERROR_CANT_ACCESS_FILE: The process cannot access the file because it is being used by another process. [MoveFileEx]"
Observations:
The error only happens when copying from the network to the local folder.
It is random: some files are copied successfully while others fail. Even if I run the compare and sync process again, the issue consistently occurs with the same specific files.
If I manually copy the exact same files using Windows Explorer, I encounter no issues.
It seems like the .ffs_tmp file is being "locked" immediately after creation, preventing the final rename.
System Info:
OS: Windows 10 with ESU activated
Software: FreeFileSync v14.8 64bit (but the error occours with older versions too)
Has anyone encountered this behavior before? Could it be an antivirus interference or a Windows Search Indexing issue? Any advice on how to prevent these temporary locks would be greatly appreciated.
My first thought was also some antivirus, especially if you are using 3rd party AV. Try with your AV disabled temporarily
