When comparing the contents of two very large folders of several gigabytes or more, the process can take several minutes or even hours and can include a huge number of files.
Currently, during the comparison, it is not possible to know the results of the comparison until the end of the process.
I suggest adding counters that are displayed during the process of the number of identical files found and the number of non-identical files found.
In addition, add a button that allows you to Suspend the process and continue it, as well as if the process has been stopped to display the number of identical and non-identical files that were tested at the end of the test process.
Feature Request. Adding status while comparing file contents
