Inquiry About Offline Installation and Thread Limits
hj.kang
I am planning to purchase the commercial version and have a few questions.
Is it easy to install the software in an offline (closed network) environment? How can this be done?
What is the maximum number of threads supported? Does the software automatically recommend the optimal number of threads based on the CPU core count?
Thank you for your assistance.
Best regards,
Threads and cores have no correlation: viewtopic.php?t=8674
Offline activation is possible, but you need internet access from something to facilitate it
