I want to set the default of "Show files that wont be copied" in "Select View" to false.
If I turn it off for my update sync jobs, to clearly see what will happen, the setting is not remembered, even if I save the job. So my proposition is to save these settings with the jobs. What do you think?
All the best
Disable "Show files that wont be copied"
Handling since v5.12:
The view filter buttons have a new right-click context menu option "set as default" which saves the value of currently visible buttons (only) as their default.
Ah, thats great, thank you. I only found the "Default view" setting :)
Cheers
Cheers
