Windows 10 Pro x64.
FFS v14.8, "normal" version - not paid for version.
On my system I run as an limited user (e.g. user "Tom") and have to "elevate" to an alternative, admin capable user to install stuff (e.g. user "Deus").
If there is not "temp" folder for user "Deus" the install halts with a message similar to:
Cannot continue folder appdata/local/temp not present.
It's not present probably because the user "Deus" has been Bleachbit'ed and is not a user I use for interactive use.
Creating a temp directory allows the install to complete.
[bug]:FFS fails to install if "temp" directory does not exist.
