Feature Request - Teradata integration for queued copy operations
beameup
I see a lot of mentions of teradata in the forums, but seems to be incidental.
I would like to see the sync operation be able to send the stream of copy operations to teradata so that the operations get queued as I go from one profile to another to sync up different folders.
Thank you for the custom context menu as I was able to get a kind of integration working there, but would be best if it was a native option.
