Sync Files to another Drive if current one Full
Grazza
I have a dive that I am backing up due to it about to fail, the drive I've compared it to to find the missing files, does not have enough space to copy the files too.
I'd like to be able to select another drive to copy the files to so I don't lose them when my drive fails.
This could be during the sync process, when it says drives does not have enough space, with the ability to send the files to another drive.
Regards
Just split the sync up into two chunks, small enough to fit
Grazza
How do you send it to a drive you haven't compared it to ?
John1234
I put together some notes regarding your situation. They describe an easy way to split your large backup between two smaller physical disk drives.
Splitting FFS backups between two physical drives.
