I don't find if it is possible to keep the value "Quit" in the progress window.
I have to select it for every synchronization.
Is there any hidden param to set ?
Thanks !
Quit after Sync
Save your FFS sync configuration as a *.ffs_batch file, and checkmark at least "Auto-Close" when saving that file. See here.
Thanks for the help, but I check the proposed updates before sync, and I think a batch file won't display them.
The batch config will display them if you run the comparison manually in FFS. Only if you run the batch config via command line will it auto run and close
