After installing Windows 11 (25H2 in-place upgrade), I noticed that file names and icons are no longer visible when I compare the directories. I didn't notice this until after updating to version 14.9. I then downloaded version 14.8 from the archive and installed it, but it didn't work. Now I no longer have the donation version.
Can you tell me if there is a solution for this?
No File List, no icons after Update to Windows 11
Are you sure that the particular files in your file list do have icons?
Do the same files display icons in Windows Explorer?
