Instllation on New Computer
Gerald Redman
I just installed FreeFileSync on a new computer.. I already have it on my old computer.
The one on the old computer is the donation edition. What do I need to do to have the installation on the new computer show as the donation edition?
Jerry
Kind of an open door: you need to install the FFS donation edition.
• If you saved the installer files of the donation edition, use those on your new computer.
OR
(both below options also work if you did not save the installer files of the donation edition)
• Use the web-link to the FFS donation installer download page in the E-mail you received after donating
If you follow that link, you end up on the web page where you can download your FFS donation edition.
OR
• Open the installed FFS donation version on your old computer, and go to Help / About.
In the bottom left corner of the window that opens you find a button "Thank you, [your name], for your support". If you click that button, you end up on the web page where you can download your FFS donation edition.
