Hi everyone,
I'd like to share a small Python tool I put together to make creating FreeFileSync sync folder pairs a bit more comfortable.
The script (ffs_gui_generator_v3.py) provides a simple GUI where you can define your source and destination folders and generate ready-to-use FreeFileSync configurations – no manual editing required.
To use it, just rename the attached .txt file to .py and run it with Python.
Hope it saves you some time and makes your FreeFileSync workflow a little easier. Feedback and suggestions are very welcome!
Enjoy!
Simple Python script to generate FreeFileSync sync configurations via GUI
