How do I fix this?
Cannot rename "X:\8886\iPhone 12 Pro Max-8886 Camera Roll Backup\20220805_123620-82a3.ffs_tmp" to "20220805_123620.mp4"
Out of 12K pictures, I have 65 of these errors all of a sudden
I am backing up from a NAS folder to a local HDD for off-site archiving.
In the settings, I am using update and tried "Database enabled or disabled" with no change.
I even deleted the local HDD backup folder and tried to have it copy everything over, and I still get this issue.
THoughts on this
Sync Updates Fail with Cannot create file when that file already exists
Is there a way to "Force" overwrite when the file exists?
There should be an error message or code associated with those errors, what is it?
Hi xCSxXenon :, I can't locate a log or history. I don't recall seeing an error code,, I spent 2 hours last night deleting all the dups it complained about and re-ran the sync job, and it worked.
Can you tell me where a log file might be stored? [MoveFileEx] maybe?
C:\Users\ME\AppData\Roaming\FreeFileSync Last log was 10-5-25 :(
