I'm not sure if I never noticed, or if something changed ... but when I run FFS in Batch Mode, I get a quick pop-up window that immediately closes. I'd like to know if I can turn that off.
and I guess I want to turn off the Progress Dialog? Is there an option that I need (or need to remove)?
Thanks.
How are you running the sync, via CMD?
hymie
Yes, I'm running via command line.
If the quick pop-up that immediately closes really bothers you, you can run the FFS sync task under different user credentials than the logged-in / active user.
