Please enhance the context (right-click) menu for the "Configuration" pane values to add an option which displays the date and time for the most recent sync, and which provides a link to access the associated log file.
In order to make this flexible across installations, it might be nice if the option called File Explorer (or equiv) for the directory, and put focus on the relevant log file. Then the user can open the file with the program of their choice (such as Notepad or Notepad++ or Firefox) by right-clicking on the file name in Explorer.
Currently using v14.9 on Win10.
Thank you.
Feature request: "Config" band context menu to link to log file
