Why? Just why? Unsucessful again. And again.
jackdashack
Does this program have to be so complicated to work? I tried it years ago and gave up getting it to work stable. Been thru a few other same types and thought, I'll give it a try again, I've got a little more on the ball. I see a lot of people with issues even IT persons having a hard time following.
I've used several 'step by step' and there's always one thing here and there not clear, and that's usually the thing that doesn't allow it to work. smh. I have no question but Why? Just why? Does it have to be so complicate or maybe not complicated but conflicted in the explanations.
ravishahani
You haven't received a response yet presumably since your post has no specifics whatsoever. That said, I would try asking your favorite AI chatbot for help. At minimum it would likely give you a sympathetic response even if you copy/paste your post into it. I found them useful for getting FreeFileSync to work for my scenario.
jackdashack
I can get it to mirrow and compare. That's not the issue. It starts getting wonky when tyring to tie in RealTimeSync. I have found Cobian and I am happy with that. Much simpler to use and does the same things. Thanks you for you time. jep
