I am running a clean install of FFS 14.9 64-bit.
I noticed some issues with normal file comparisons, where the program did not register the contents of selected folders, but merely advised "No files to synchronise", so I deleted my instance of FFS, downloaded and re-installed the latest version and set up a test case of two folders containing exact copies of files and subfolders, then attempted to compare them. The result: blank side-by-side comparison panels and the advisory "No files to synchronise". Nothing to see here, folks!
Perplexed.
Any hints or sage advice greatly appreciated.
FFS Not Registering Folder Contents
FFS doesn't display equal line-items by default.
Look at the bottom of the window, should see an '=' box you can click
Thanks for that, seems to resolve the issue nicely. Much appreciated :)
