retitling saved batch job files in a folder and clicking on them to start the process.
tsoilihoi
I have 9 specific jobs from different source locations to 3 removable western digital external drives.
(As I have to unlock them creating a secondary drive letter and because the data is coming from varying drives and locations, I have to do the syncing from pc to the particular drive, manually.
Now most program have you create a menu that is permanent. I believe that the menu on the left is
volatile and just shows recent runs... So I batch saved each run to a folder and re-titled the ff_gui files (so I would know which one was for which target to which destination.
I found that if I click on the ff_gui file that it brings up the program.
I moved the nine files to a folder and am prepared to connect up each external drive and click on the appropriate batch file.
This works, am I missing anything. As I mentioned other sync programs allow the creation of a permanent menu
Now I could make 9 batch files file path to the programs exe and the first parameter path to the ff_gui file.
Or one batch file when I fill in a value 1 - 9 and it runs the correct ff file... but just clicking the particular file works.
Again, I can't run it unattended as there are files coming from multiple folders on different pc drives
Thanks for any help.
paul
Open FFS, then in FFS select 'Open', then select your configurations you saved. This will put them in that panel permanently
tsoilihoi
Thanks you!!
