RealTimeSync on Windows Server 2012 doesn't update files
eringobra
Hi Zenju,
I don't think Server 2012 is supported but FreeFileSync runs fine on it. It's RealTimeSync that I wanted to check with you about. Here are two screenshots, do you see anything wrong with the configuration?
http://i.imgur.com/1OnHh7k.jpg
http://i.imgur.com/dcgnvmV.jpg
I am able to launch RTS but never get any logs and new files I create don't get synced.
Thanks!
600 seconds? that's 10 minutes of *idle* time before RTS reacts to a change. On a busy server this idle time span will never occur.
eringobra
600 seconds? that's 10 minutes of *idle* time before RTS reacts to a change. On a busy server this idle time span will never occur.Zenju
Well, that would explain it! I incorrectly assumed it was idle time for RTS itself, so it would sync every 10 minutes.
You're so fast in replying, thank you!
