Possibility to download older "business edition" versions
mvanderkruk
We have recently bought a license for one of our customers.
Currently they are experiencing issues with the latest version 14.9 (RealtimeSync stops syncing changes)
We would like to try if any of the older versions (14.7) have the same issue. But unfortunately we cannot activate these because of the license which is tied to the version of the software.
Just like described for Donation Edition, there is no way to download previous versions of your Business Edition.
Only if you retained the installation files of an earlier Business edition version you can re -install that earlier version.
Just for trying if an earlier version of FFS does not cause the problem you are experiencing, you can download a previous version of the FFS standard edition and temporarily install that.
