I have a donation version of FFS on my home PC. However, my laptop says it's not the donation version. Do I need to donate again (per PC) if I need the same version I have at home?
Donation Edition
Apparently you installed the FFS Standard edition on your laptop.
You have three options:
1) If you kept the installation files of your Donation edition, use those to also install FFS .
on your laptop
2) Click the link in the E-mail you received after donating
3) Open your installed FFS Donation Edition on your home PC and in the top menu go to Help / About. In the bottom-left of the "About" screen that opens you see a button "Thank you {your name] for your support". Click that button.
Either 2) or 3) above should bring you to your Donation Edition download page, that has the form
https://freefilesync.org/thank-you.php?tx=[Your 18 digit/character unique code]
(Save that page-link as a bookmark or shortcut for potential future use).
Download the relevant, most recent installation files of your Donation edition, and install those on your laptop.
on your laptop
Thank you. All fixed.
