Synchronization issue
AstroChili
I would like to use FreeFileSync to back up my PC's data. However, when I start the synchronization, I get the error message shown in the attached file. The volume to transfer (G:\Astro\Chili) is 441 GB, and my available space on the drive is 2 TB. I don't understand where the error is coming from.
Thank you in advance for your help.
Best regards
viewtopic.php?t=13040
Anything in there helpful?
Hemps
You can disable this warning - Under tools - Options - Show hidden..... - search the list and untick warning
You can disable this warning - Under tools - Options - Show hidden..... - search the list and untick warning Hemps, 28 May 2026, 08:58
This is not a warning, it is an error, and it should be addressed instead of hidden
