I really like this program works great for one to one, however I have a slight different problem.
I have a source drive
the backup of the source drive is spread over 5 smaller drives
the source drive is not broken down by backup drive so what I need or want to do is:
is to scan the source drive and compare it to all the backup drives.
anything on the backup drives not on the source drives get deleted
and anything not on the backup drives get copied to them ideally it would save to the drives with lowest space and then move on as needed.
Is this possible?
is this possible with the software
No. You have to specify the scope of each backup to each drive. What you want is disk management, which FFS doesn't do. Something like DrivePool sounds up your alley for this
I am not sure drivepool is what I am looking for.
I want something filesych does only to compare one drive to 5 other drives. I don't want to create virtual drive.
It's basically the same thing I do with filesynch now for one on one but would become one on five
