I currently use Allway Sync to transfer files between a PC, USB and laptop but it is no longer supported. I normally use the PC but when I go away I take the laptop, with the USB as a safety backup. Which version of FreeFileSync do I need to carry out the same process? Do I need the Portable version or can I do it with a copy on each device using the same login credentials?
Or would I need the business version and have to purchase two copies?
Which Version for PC to USB to Laptop?
Standard version of FFS doesn't have any login credentials and can be installed on as many devices as you want
