Would it be possible for FreeFileSync to remember the size of the Synchronization Settings window?
I use long paths, and that window is so narrow it results in wrapping, which makes it difficult to read each line. I'm constantly having to resize that window every time I want to add/remove inclusion or exclusion specifiers.
Thank you for your consideration.
FR: Remember size of Synchronization Settings window
