Mirroring not finding files in top folder
bobbybill
Mirroring a top folder mirrors all subfolders and files but not the files in the top folder. Do a comparison first then mirror sync to One Drive and ASUS Web storage separately. (Some file names within sub folders are updated on mirror with One Drive but OK.) How to fix please.
favoredrive
do you use include/exclude filters? you could also try rclone...
bobbybill
Do not edit filters at all. I'll look at rclone Thanks
favoredrive
This is the command you need: https://rclone.org/commands/rclone_sync/
Gianni1962
The Comparison before the Mirror Sync shows the files in the top folder?
If Yes, then what are the errors thrown in the Sync operation?
Screenshot of filter settings?
bobbybill
In trying to resolve this I have found a a problem on my PC set up which is causing this (duplicate files being created). I'll stop this. Thanks for the input and help.
