Two synchronization tasks with one source
ksg
There are two mirror synchronization tasks with the ‘Use database file to detect changes’ parameter (drive E on the left):
1. From drive E to drive K.
2. From drive E to drive M.
I run the first task first, then the second. When running the second task, the program does not detect changed files during scanning that should have been synchronized. What is the reason? Is it because the program uses the same database file for two different tasks? How can I do it correctly?
ksg
I didn't find the reason for my problem there: why the program doesn't see the need for synchronization.
favoredrive
Which changes are not detected, on E or on M or both sides? What if you run task 2 first, then task 1?
ksg
No modified files are found on drive E for the second task (I have it specified that the mirror is with drive E on the left).
favoredrive
Strange, it works for me. Are you sure that the files are modified on E and not K?
Try to reproduce it in different locations (can be any 3 folders for testing) and modify files at the source.
ksg
I tried to reproduce the error using a simple example with three folders, but it didn't work. I'll investigate further; perhaps I did something wrong with the exceptions. Could it be that copying from folders is one thing, and copying from the root of the drive is another?
favoredrive
What did not work? The second task again or the reproduction?
Exceptions?
I guess it's something else...
