can not copy certain files error 1920
theedragon
normal files (doc and pdf) in normal directory - that works for similar files in same directory
(files are not corrupted - can be open in word and pdf programs)
![test] (Image)
here is the program window you can see the 'missing ' 6 files
theedragon
hmmm . . . why is the right side of the 2nd image missing (is there a 'size' limit ?)
theedragon
here is the missing part of the above image
Probably an issue related to OneDrive not accepting the ffs_tmp file extension. Work around would be to disable "fail-safe file copy" in menu -> tools -> options.
joaopaulo1511
Probably an issue related to OneDrive not accepting the ffs_tmp file extension. Work around would be to disable "fail-safe file copy" in menu -> tools -> options. Zenju, 29 Jun 2015, 15:00
Hi! Would be possible to overcome this OneDrive limitation by using "ffstmp" extension? I think every name which has lots of "_", "-" and numbers on it causes trouble to OneDrive or FreeFileSync when the extension also has "_" on it.
I tried syncing "K-Lite_Codec_Pack_1360_Full.exe", then it triggers the error 1920 message. After I renamed it to "test.exe", the sync is fine. If I rename back to its original name, the error reappears.
joaopaulo1511
It seems that merely moving the file which triggers the error outside OneDrive folders, waiting OneDrive to recognize the changes, and then moving back to the original place solves the problem.
