I changed drives so I changed the drive letters in the sync settings, saved it, then saved to a batch file, then drug and dropped the batch file into RealTimeSync, the drive letter changes came over fine. I then clicked on Start but nothing happened. Hovered over the icon in the tray and it was waiting for a file to run in the "C:\Program Files\FreeFileSync\N\Sync Backups\Patreon" folder. As you can see, there is an "N" in the path and I can't find a reason why.
I may have to start from scratch if I can remember how the heck I put this all together, I do recall it took me a while...
TIA!
Rick
Path has an N in it
