Unable to access Google Drive with FFS 14.10
pablowannafly
Hi, I tried Google Drive sync with FFS 14.9 on Mac with Sequoia 15.7.5 and it worked fine.
With FFS 14.10 something is wrong and it seems that the connection can't be established.
FFS seems connected but it freezes trying to connect or even trying to read the subfolders while choosing the right path. FFS doesn't crash, just not responding anymore. What to do?
Thanks!
pablowannafly
UPDATE: SOLVED
I tried to reinstall v14.9 first and then v14.7 but I was having the same issue.
Then I reinstalled v14.10 and first of all deleted the google drive account saved in the option access panel.
Just to be on the safe side, I closed FFS to save the settings. Once I’d reopened it, I repeated the steps to add the Google Drive account and now everything is working as before.
