FFS sync configs include a useful option to run a command after the sync has completed. What I will appreciate is for sync configs to also have an option to run a command when the user presses the 'Compare' button.
Yes, I could use a batch file or PowerShell script to encapsulate FFS, but that would ruin my workflow, as I find the FFS GUI very useful and I only want to run this command on 1 or 2 of my many sync configs. I manually run desired sync configs one after another within the FFS GUI; having to terminate FFS and then relaunch it inside a custom wrapper just for 1 or 2 sync configs would break my workflow.
Thank you for your consideration.
FR: Sync config option to run a pre-compare command
