I have a bunch of duplicates print throughout the operating system, I would like to be able to his freefilesync two designated to consolidation folder and copy all the files that duplicate other folders into the consolidation folder.
I'm not sure what's doing it but I'm in the out files that ended up in xxxx 2.PDF xxxxx 3.PDF xxxx4.PDF
Is there a way to tell freefilesync about to copy those files to the new location?
Freefilesync help you get rid of duplicates
There is a free open source app that might be better Suited for locating and dealing with duplicate files.
It's called dupeguru
https://dupeguru.voltaicideas.net/
It will rapidly locate all duplicate files and then you can decide what you want to do with them.
