Real time sync with local NAS
optixcom
We are tring to create a real time sync between a SSD on computer (ex: d:/source) with another SSD attached as NAS to the FritzBox router (ex: ftps://....). The NAS can be synced with local computer SSD with no problem. However, when we tried to provid the folder path of NAS in the Real Sync program, the command line is empty. It seems it can not generate the command line correctly. How can we solve it?
John1234
What you need to do is use a third party utility program to Mount Your nasdrive or server as a drive letter in Windows or a folder in Linux and Mac.
Then you just pick the drive letter in free file sync.
There are two products that I normally use.
1. Air live drive (windows only)
2. Rclone (win,mac,linux)
optixcom
Thank you very much! We will try.
You can also click the cloud icon in FFS and try accessing via FTP/FTPS
