[Invalid] Unable to download Donation Edition with my download manager
therube
No longer able to download Donation Edition with my download manager?
(Has always worked in the past. http://www.xi-soft.com/default.htm
14.10 worked, on 6-29-26. I did put in a newer version of NT...)
08/10/2026 11:13:28 AM.736 Connecting to freefilesync.org:443
08/10/2026 11:13:28 AM.738 Connecting to 172.67.129.95:443
08/10/2026 11:13:28 AM.753 Connected.
08/10/2026 11:13:28 AM.753 Establishing SSL session.
08/10/2026 11:13:28 AM.775 GET /supporter-edition/FreeFileSync_14.11_%5BDonation_Edition%5D_Windows_Portable.zip<...>%23%20 HTTP/1.1
08/10/2026 11:13:28 AM.775 Accept: */*
08/10/2026 11:13:28 AM.775 Referer: https://freefilesync.org/thank-you.php<...>
08/10/2026 11:13:28 AM.775 User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0)
08/10/2026 11:13:28 AM.775 Host: freefilesync.org
08/10/2026 11:13:28 AM.775 Connection: Keep-Alive
08/10/2026 11:13:28 AM.852 HTTP/1.1 400 Bad Request
08/10/2026 11:13:28 AM.852 Date: Mon, 10 Aug 2026 15:13:28 GMT
08/10/2026 11:13:28 AM.852 Content-Type: text/html; charset=UTF-8
08/10/2026 11:13:28 AM.852 Content-Length: 40
08/10/2026 11:13:28 AM.852 Connection: keep-alive
08/10/2026 11:13:28 AM.852 x-robots-tag: noindex
08/10/2026 11:13:28 AM.852 cf-cache-status: HIT
08/10/2026 11:13:28 AM.852 vary: Accept-Encoding,User-Agent
08/10/2026 11:13:28 AM.852 Server: cloudflare
08/10/2026 11:13:28 AM.852 x-content-type-options: nosniff
08/10/2026 11:13:28 AM.853 Cache-Control: max-age=3600, public
08/10/2026 11:13:28 AM.853 strict-transport-security: max-age=31536000; includeSubDomains; preload
08/10/2026 11:13:28 AM.853 referrer-policy: no-referrer-when-downgrade
08/10/2026 11:13:28 AM.853 content-security-policy: frame-ancestors 'none';
08/10/2026 11:13:28 AM.853 alt-svc: h3=":443"; ma=86400
08/10/2026 11:13:28 AM.853 Age: 1568
08/10/2026 11:13:28 AM.853 CF-RAY: a28ff1db7cc682d5-IAD
08/10/2026 11:13:28 AM.853 HTTP server error.
therube
Older version worked.
I suppose it is the encoding in the GET, '%23%20 HTTP/1.1' ?
08/10/2026 11:18:08 AM.019 Connecting to freefilesync.org:443
08/10/2026 11:18:08 AM.032 Connecting to 172.67.129.95:443
08/10/2026 11:18:08 AM.052 Connected.
08/10/2026 11:18:09 AM.125 Establishing SSL session.
08/10/2026 11:18:09 AM.157 GET /supporter-edition/FreeFileSync_14.11_%5BDonation_Edition%5D_Windows_Portable.zip<...> HTTP/1.1
08/10/2026 11:18:09 AM.157 Accept: */*
08/10/2026 11:18:09 AM.157 Referer: https://freefilesync.org/thank-you.php<...>
08/10/2026 11:18:09 AM.158 User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0)
08/10/2026 11:18:09 AM.158 Host: freefilesync.org
08/10/2026 11:18:09 AM.158 Connection: Keep-Alive
08/10/2026 11:18:09 AM.562 HTTP/1.1 200 OK
08/10/2026 11:18:09 AM.562 Date: Mon, 10 Aug 2026 15:18:09 GMT
08/10/2026 11:18:09 AM.563 Content-Type: application/zip
08/10/2026 11:18:09 AM.564 Content-Length: 23411671
08/10/2026 11:18:09 AM.564 Connection: keep-alive
08/10/2026 11:18:09 AM.565 x-robots-tag: noindex
08/10/2026 11:18:09 AM.565 content-disposition: attachment; filename="FreeFileSync_14.11_[Donation_Edition]_Windows_Portable.zip"
08/10/2026 11:18:09 AM.570 Cache-Control: max-age=3600, private, immutable
08/10/2026 11:18:09 AM.571 Server: cloudflare
08/10/2026 11:18:09 AM.572 x-content-type-options: nosniff
08/10/2026 11:18:09 AM.572 vary: User-Agent
08/10/2026 11:18:09 AM.573 strict-transport-security: max-age=31536000; includeSubDomains; preload
08/10/2026 11:18:09 AM.573 referrer-policy: no-referrer-when-downgrade
08/10/2026 11:18:09 AM.574 content-security-policy: frame-ancestors 'none';
08/10/2026 11:18:09 AM.574 alt-svc: h3=":443"; ma=86400
08/10/2026 11:18:09 AM.575 cf-cache-status: BYPASS
08/10/2026 11:18:09 AM.575 CF-RAY: a28ff8b4fd63d6a9-IAD
08/10/2026 11:18:09 AM.583 Start receiving data.
08/10/2026 11:18:11 AM.011 Finished at 23411671
Odd...
therube
Actually... It looks to be an odd interaction between Net Transport 297 & FlashGot (https://flashgot.net/).
When I FlashGot the link, for whatever reason a # (symbol, %23) is being appended to the GET.
If drag the link into the download window (in Net Transport), that does not happen.
And it also does not happen, regardless, in the older version of Net Transport.
(When I put in the more recent NT, it oddly was not picked up, automatically, by FlashGot & I had to add it manually.)
So it is the GET (in combination with NT & FG).
In one case, I am, '%23%20<sp>HTTP/1.1'
& in the other, '<sp> HTTP/1.1'.
(I've not run across such issue - anywhere else, that I can recall, at least.
Now, I'll be more cognizant, in case I do...)
