FreeFileSync not showing last sync in the left menu on linux mint
_GTA_
how do i fix this? the last sync checkbox is enabled in my freefilesync but it is still not showing for me on linux but on windows it is does.
JohnHaggerty
Hi _GTA_,
This looks to be the same problem as in my post on 1st August.
viewtopic.php?t=13180
I haven't had any responses yet but if I get any I'll update you.
I'm running FFS 14.11 on Linux but it happened on 14.10 too.
I'm not sure about my 'last sync checkbox' being enabled as I can't find it on my system.
Regards,
John
_GTA_
hi, i fixed it, it is was hidden.
JohnHaggerty
Hi _GTA_,
Glad to hear you fixed it. How did you do it? Where was it?
I've checked ~/.config/FreeFileSync/GlobalSettings.xml and can't spot anything.
I've even compared the current file with backups of it taken in January (and March and June) without any joy.
Regards,
John
