when a comparison reports significantly different folders, I have to confirm the warning before the sync starts. If the sync then runs without any error, the config list still shows the yellow triangle instead of a green check.
Since confirming the warning means "yes, this difference is expected", shouldn't the result be a green check? Currently the only way to clear it is a second sync that has nothing to do.
Green check after confirming the "significant difference" warning?
