Good morning and greetings to all.
I've been using this excellent program for a long time and I must say it perfectly meets all my needs, but there's something I've been missing for years and I think it could be helpful.
I have several multi-pair sessions defined with inclusions and exclusions, and even with different copy types, but sometimes for some reason I need to exclude a pair of directories before comparing them. The only way I can do this is to delete the pair and remember to exit without saving.
Couldn't you add a button next to the sort and delete buttons that would allow me to enable or disable a pair before performing the comparison?
Thank you.
Directory Comparison
Run a Compare.
In the Compare result window or in the Overview window (default bottom-left) select the folder(s) te be (temporarily) excluded, and then right-click and select and choose "Exclude temporarily" (or Space).
Then run your Sync.
Then run your Sync.
Thank you for your response.
But I've had to wait a long time for a large folder that I don't want to copy right now.
